  • 8 months later...
West Virginia is a great place to ride. They have a lot of state sponsored riding areas.  Check out the New River area.. Take the Raft trip if you are brave.
Lots of trails for ATV and SxS.
They New River is a wild ride.  The first set of rapids below the raft was three RR coal gondola cars submerged after a derailment .  I lost my sun glasses in the first rapids. And keeping our tops on with the water crushing down across us was a constant challenge for us three girls in the raft.    The guys were no help.  Great trip...I recommend it.
Here is better pic of rafts on our swim break. Its all day on the River.   Everybody has to paddle hard to keep the raft moving tough the water fall rapids (11 foot vertical drop) or the rat will be pulled under by the "hydraulics" of the violent water.  The guide sits on a wood platform steering the raft.
We took several swim breaks.
Cannot wait until this fall and go back ATV ing along the New River W Va.  West Virginia is a great place to ATV or SXS.
BTW...some trails allow only ATV's..Check details.  The river normally has very clear water.
There are beautiful camping facilities in the area.  I stayed at one fairly close by that had a lake and beach.
It gets busy there in Summer but Camp Sites are nice and exciting also.  Here is a pic of a rapid from internet.  You can see its rough.
  • 3 months later...
Heding back up there to New River.  The Bridge is  closed one day a year. so people can walk across it. They also Bungy Jump from the bridge..OMG not me  I have issues with committing suicide.....  They para sail also.
  • Confused 1
Yes,  Exit 48 (WVa) off I-77 north bound to US 19  (Toll Rd) toward Beckly.  South bound on I - 79 (WVa) (from Pittsburg) exit 57 onto US 19.
  • 4 months later...
    • By joezee13
    • By middlebrookgt
    • By Ejwill
    • By Need-help-with-quads
    • By Hagbard
      Have a long story that I'll attempt to make brief. I picked up what was advertised as a 1987 LT230E with no cam or valve cover, harness dangling, no plastics, and all kinds of slop in every bushing and bearing, but hey, it was free and I love a challenge. Local guy had a couple 87 230E motors he was selling on craigslist, picked up one of those and a pisspounded DG RCM and header for $100. Went through the harness to start sorting things out and noticed a few key differences, like the stator connectors didn't mate up, one round and one square. Rubbed some of the grime off and found a VIN, Lo and behold - I have a 1990 LT160E, not a 1987 230E... By the grace of who knows what, the 230 just so happened to mount up directly to the 160 frame with no mods. Wasn't until I had broken the seal on starting to chase down the harness leads that I found out.
      As it stood, advertised as a 1987 230E
      After a bit of elbow grease and some eBay raiding.
      Made a new seat cover and found a set of plastics, New carrier bearings, and brakes all around.
      Pulled the steering and front suspension all apart and gave it some love with new bushings and tie rods
      Ordered a small fortune in NOS and China parts from eBay and RockyMountain and after a couple weeks of wrenching and soldering I have a nearly complete wheeler, in pretty decent shape. Cleaned up a Mikuni carb I had laying around and mounted it up with a cone filter and a Lowe's Racing™ intake boot, and fed it some gas, primed the carb and tugged on the started rope a few times, and sure enough it belkched out some soot and fired up, ran for a couple seconds and died. No sputter, just shut off. Checked for fuel startvation, vacuum in the tank, no problems there, plenty of gas in the carb. Suspected clogged air jets, so I pulled it out of the boot and gave it a shot of ether, and it did the same thing, fired up, ran strong for 2-3 seconds and shut off. Then suspected I f*%#ed up the wiring harness somewhere, and re-traced all the leads with my newly colored wiring diagram, thanks to my kiddo's Crayola marker collection, and everything looked good. Started to suspect the CDI, solenoid, or coil might be faulty and was flipping thru the manual when a buddy stopped by with a pair of boat seats for me to reupholster for him.
      He's a little bit of a savant with engines and electronics, and he got curious when I told him my predicament. Three minutes later he said "Hand me a pair of needlenose?" which he used to short the neutral switch to ground, and had me give it another tug. Fired up and ran great, no shutting off, so we deduced that the neutral switch must be at fault and after he left, I pulled it off to troubleshoot, and decided to flick the shifter a couple times with it off to see the little nubbin go around in a cricle. It didn't. I should mention at this point that I had previously changed the oil and while doing so, I took the opportunity to adjust the clutch without consulting the manual because I'm the dumbest guy I know. I did it according to the procedure I had learned for the LT185 I have, and figured the adjuster itself looked the same, they must be the same thing. I loosened the 10mm lock nut, and started turning the adjsuter screw clockwise waiting to encounter resistance, and then back it off 1/8 turn. I was really surprised when it kept turning and turning, but figured it must have been WAY out of adjustment, and went on with business. Figured I might need clutch plates at some point.
      Encountered this problem, and actually read the manual and the procedure is entirely different, and I realized that I had basically "adjusted" it into oblivion. I have since drained the oil and tried to re-adjust it twice, with no luck. Anyone have any idea what I can or should do to correct the issue, or am I missing something else entirely here? (chain is off and sprocket nut is loose, if that makes any difference.) Any insight or advice would be appreciated, thanks.
