Hi all, new to here, looks like a great site. Own two atvs, an at the moment not working honda fourtrax and a yamaha moto4 of some description, trying to work out what model yammy it is.
Welcome, you have 2 of the greatest ATVs produced good luck getting them going.
The Yamaha Moto 4 350 or YFM350ER eventually became the prototype of various Yamaha models such as Warrior, Raptor Big Bear, and other YFM designations. Fitted with a bigger 329-cc engine, this sport ATV was designed for strong midrange pulling capabilities and serious mudding and riding in shallow water.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
