Similar Topics
By Buell
Hey guys, figure you guys would have some helpful direction or answers.
So, 05 Sportsman 700 carb, new carb, fuel pump, new plugs, new air filter, new everything I can think of that is usually the running issues. Starts up fine, seems to run fine, but if under load, two people, or even one person, up a hill, or pulling a drag chain for the driveway, it starts to cut out and sputters and loses all power, until I back off on the throttle and just barely try to let itself catch itself and then I can take off again.
I am going crazy trying to figure this thing out. Other than that, the quad runs great. Parents bought bran new, just used around the property, 5000 miles on it. Any ideas???
By Johnnyhorsepower
I finally found an awsome app for your phone that shows you on a map all the trails near your location. You can read or add reviews, look at picts...etc
Its called: atv escape
John
By speely31
Currently working on a 1992 Yamaha Big Bear 350 that idles perfect but cuts out with any kind of throttle. We replaced carburetor and head to carburetor boot.
Put in a new spark plug, the old one was black as hell, unsure if it was caused by old carburetor or current misfire. This problem similar to the rev limiter you see on newer models when
differential is locked or in reverse. I don't think this machine has that feature but I could be wrong? I suspect an ignition component is breaking down but at the moment I don't have access to a wiring diagram or workshop manual but I'm working on that. Are the e-manuals any good?
Any ideas?
By Tiffany Rowland
I bought an 07 honda trx400ex for my daughter 11th birthday. I've been having alot of fun fixing it up but after reading some of the posts about safety I think I may have gotten a little carried away. I put an exhaust on that added 10hp, a k&n performance filter, new carb, a stage 3 rev box and coil, and I wrapped the exhaust. The top speed started out at 92mph and we're well above that now. My main concern, though, is low end throttle. Is there any way I can do something thate will decrease the rate of acceleration without taking off the modifications I've done? She's super cautious and won't go over 10mph but I'm worried that she may have a hard time controlling it after these last few upgrades.
By stinky
I have an Outlaw 110 that will struggle to turn the engine over. Jump starting doesn't help other than the battery will drain LONG before the bike eventually starts, so is required. If you keep messing with it long enough it will eventually magically begin to crank fine and sometimes finally start. Once we finally get the bike to start and warm it up thoroughly, it will turn over and start just fine the rest of the day like nothing ever happened... next day it won't turn over again. Internet research has found lots of people saying they replaced starters, starter clutch, wiring, etc. but with only about 50/50 success rate for their particular problems... and I never found anybody describing a problem like mine, so I'm looking for advice/experience. Would rather not just start blindly throwing parts at it. Does anybody have any thoughts/ideas?
Similar Tagged Content
- 0 replies
- 1,499 views
- 0 comments
- 2,814 views
- 4 replies
- 2,166 views
- 1 reply
- 5,936 views
- 52 replies
- 11,749 views
Gallery Images
