Do you mean it has a slow leak, or you can't get the bead to contact the rim to start inflating it ?
If it's a slow leak you can put something called "slime" in the tyre, then rotate the tyre and wheel while it's tilted on it's side so the slime gets around the bead and seals the leak.
If you can't get a new tyre to fit on one side, take it to a bike shop..
    • By Sporpo
      Have a 2018 Sportsman 850 SP with factory 26x10x14 rears and 26x8x14 fronts, and it is now time to replace them. So, is it reasonable to replace all four to now be the same size of 26x9x14? Replace with radials, of course, and at least 6 ply rated. And, can a 27" tire fit on the factory wheels? Thanks for any replys...i know this has been hashed and rehashed so many times, so thanks for all replys, and, yes, this bike has had a literal ton of cash put into it just to get it running again, and still needs some tinkering, but it will be a work bike, it is not a pleasure/recreational bike like it was intended to be... LOL
    • By wjmedic
      right front hub again
    • By qcm413
      Hi,
      thank in advance
    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
