Have you checked the wiring ? Check the stator wires have a good connection all the way to the cdi. Check the kill switch or disconnect it.
Check the stator resistance readings from the cdi unit. That will confirm their connections are good.
If you tell us the history of the bike and the problem it might help..
10 hours ago, Atomusthenes said:
I put a new ignition in it it is a cheap aftermarket one doesn't have the correct plugs but has the correct wiring scheme
If you are referring to the ignition switch, since it did not come with the correct plug and the aftermarket wires are rarely the right color i would confirm that you have it wired correctly before proceding . You still might not be getting power to the CDI  but have it correct for other things.
    • By Memphis
      Regards
    • By Tim Keiper
    • By Trent Finnessey
    • By Dumass
