can someone tell me which side the neutral and reverse switch are on a 1986 honda trx 200 The service manual does not say which side, i got the lites pulled out and looked at them and i think the switches are bad. i just don't know which side they are on , the photo in the book just shows how it looks after a cover is off and not which side its on.i would just like to know so i don't have to take stuff off that i don't have to.  thanks for any info on this.......
Remove the junction box cover. Disconect the neutral switch wire connector . Check for continuity between the light green/red wire terminal and ground. The switch is good if there is continuity with the transmission in neutral.
For the reverse switch check continuity between gray and ground good if you have continuity with the transmission in reverse.
Poor photo from service manual.
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
