Good work! I built one for motorcycles do a lot of that kind of work, the only problem i have is getting them on and off i ended up mounting a winch to get them on and off, kind of works.
  • 3 months later...
    • By jay41198
    • By Asand211
    • By TravisCr
    • By TravisCr
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
