There is a throttle restrictor on the housing, i just assumed you had already checked that, it is a small screw  to keep you from going full throttle, mostly there so you can set to keep young unexpierienced riders from going full throttle.
You could also check the throttle plate to make sure its opening all the way at full throttle. You can adjust the cable to make sure that is happening. You dont want to adjust it so far that the plate does not close completely , there is a fine line for it to be correctly adjusted.
Im not sure about which wire would be cut to increase speed.
    • By BillR94
      Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
      I have noticed lately that the ATV tires i generally buy have upped in price quite a bit. The Kenda EX that i generally get are sold out and not available at this time, the EVO which is usually my second choice has increased 50.00 on a set of 4. The HTR Kendas best tire is now 150.00 per tire. Even the Sun F have increased but not so much as the others.
    • By motox88
    • By Chucksta
      Any ideas?
