2019 450i ?
By mehim
By HeWasRidinDirty
The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
By Adamb2025
By davefrombc
Anyone carrying a power box when camping with their ATV? I built a custom one. I used a marine battery box that has 2 50A Anderson Grey connector outputs ( changed one of the greys to a red), an accessory socket and2 USB outlets,and a battery voltmeter .. I added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the output posts.. To charge the 100Ah LiFePO4 battery I put in the box, I added a DC to DC charge adapter that I made input connectors for to allow charging the battery from a vehicle's accessory socket or a solar panel.
It was a fun project.. Besides having a 1,000w power box for 120V ac , USB and 12v accessories using the 10 A socket. I have 50 A Anderson connectors and the 120 A connector to run things like a 12v electric outboard for fishing trips . The LiFePO4 battery only allows a max output of 100A so it can't be used for something like jump starting, but it is half the weight and delivers twice the capacity of a lead acid battery running accessories.. Commercial pow2er boxes don't deliver high draw 12v output to run things like the electric outboards. That's one reason I custom built mine. One box that serves for both camping and fishing.
