Similar Topics
By KennyB
Anyone know where I can find preferably new lower control arms with ball joints for a 1988 Honda trx300 Fourtrax 2x4?
or a place or person that can build me new ones
By Thegrizz
So, I just bought this quad off a acquaintance of mine… anyways, it’s missing the airbox which I’m trying to purchase if I could only figure out the year and what model of lt230 it is due to having only 9 visible digits for a vin…guy said he had the title at one point and lost it when he moved houses after the flood of 08 in Iowa….I just desperately need to know what model this thing is so I can start getting to work on it….it does run after a good carb cleaning….I’m having trouble getting it to idle though due to essentially just having a rigged up air filter with no airbox on the bike…I’ve sanded down the plastics and it looks like the original color was orange and the seat I believe is either from a different Suzuki or it’s been painted gold and black? The plastic nose part is originally black…it has the lever for reverse by the sprocket it has a pull string to start and I think originally it has electric start as well….idk I’ve had to bypass and use a screwdriver on the starter Solenoid to get it to start …someone has definitely done some rigging with the wiring as well.but if anyone has any clue what I need to look for to identify the year and actual model so I can get the right stuff. I’d appreciate it.
By quadfamily
Hello everybody
I am in search of an lt 80 kids quad rear swing arm. The one on my kids quad broken and am looking for replacement. If you guys know of any upgrades or swaps I could od I would appreciate that also.
By Slicktop
Is there anywhere I can obtain forward control arms for this model since i'm running 29.9 - 9.5 - 14 Outlaw 2's. having an issue with them hitting the plastic near the footboards when i turn. yes, i'm aware they're large for that model, but when you get the tires for $300 and only 30 miles on them, you do what you have to do. Looking for advise to help with clearance.
Already put a 2" highlifter lift kit and 1.5" spring spacers along with adjusting the coil springs to the last notch for less body rock and possibly more clearance.
By Theprof
Hi can anyone help me please to identify the model of my quad i had an SMC quad given to me by a friend in greece and it needs a bit of work , pads all, round 4 new tyres , rear axle bearings but i am having trouble identifing the model there is a sticker on the frame with STANDARD MOTOR CORPORATION e1 - 2002/24 - 0276 - 00.
Many Thanks Alan.
Similar Tagged Content
Gallery Images
