I'm guessing that the start up message is the service reminder? If so, here's what Gemini had to say:
To reset the "Maintenance Required" indicator on your 2015 Can-Am Outlander L 500 Max, follow this exact button sequence:
  1. Turn the key to the ON position without starting the engine.
  2. Press the Mode/Select button on your gauge until the display shows the odometer.
  3. Cycle the high beam switch from high to low 3 times quickly (within 2 seconds).
  4. Turn off the ignition.
The next time you start the machine, the message will be cleared.
Thanks for the info, that will come in handy.
But in my case, the previous owner had their name programmed in by the dealer so on startup, their name scrolls across the screen. I’d like it to revert back to the factory startup message.
As VR described this should preform a hard reboot and allow you to and allow you to enter your new information, the button sequence could be off depending on the cluster, your service manual should describe the button sequence needed for the particular cluster you have.
Thanks, I’ll give it a shot and report back
Edited by rjsummer
To correct spelling
    • By canamKID
      20260711_150338.mp4
    • By realpilot
    • By OldATVowner
