Any help would be great,
Thanks!
There are several checks i go through on a no spark situation. You have already done the first on my list, correct OHM range on the pickup coil. Te next is check to make sure you are getting voltage to CDI also make sure it has a good ground, check all connections going to CDI from pickup coil. Make sure you are getting 12V to the main coil and it has a good ground. Even though you r OHMs were correct on pickup coil check to make sure its putting out voltage i do that with an analogue meter digital is not sensative enough to catch the miilisecond voltage spike from the coil, unless you have a peak voltage adapter or your meter could possibly have one built in if its expensive enough mine does not so i use the analogue meter. Generally if it passes all these tests then i  replace the CDI.
I pulled the stator and realized it only has a pick up coil and not an energizing coil... The battery is completely dead and I had a jump pack hitched only to the cables. I was only getting 10.8V and it seems this CDI is very picky for voltage from what I have read. I have the battery charging and if it doesn't charge then I will pick up a new one. I have a Fluke 87 V, and I will have to look at voltage once the battery is charged.
At least it gets an oil change at this point... xD
Thanks,
    • By cruteg8
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
