Edited by 88bigbear
Forgot something
 Welcome to the forum ! You have replaced everything spark related. I think at this point i would check out the start stop switch a little closer i have seen them cause more problems in the older Big Bears, only getting 3 volts out of the CDI couuld also be a ground issue, check all of your connections and make sure you are getting 12v to CDI. I have also noticed wiring harness issues also on the bears it been a long time since i have worked on a 350 but iknow on the 400s its easy to get misalignment of the pick up coil in fact the last one i worked on previous owner had it on upside down.
Probably not much help all i have for now, but im thinking about it. Just wanted you to know we are listening, but this is a tough one.
I honestly didn’t know the pick up coil could go in wrong but would that still be a problem as I had the bike for a run after I replaced it and it was great, spark Only died after parking for a couple days, Ohms test was good aswell on this pickup coil, I have most of the harness open Iv found a few gremlins and repaired but still no fix and tested the killswitch at the switch so maybe a problem further down in the wiring
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By TomJulio
      any ideas how to correct
    • By Callaway
