so do you think the acrtic cat motor will fit into the quadmaster
I won't to say no, but I can't remember. If you could find the dimensions for both engines it would let you know for sure. Whats wrong with you current motor?
    • By jay41198
    • By tepin
    • By Shorty51
    • By LMI
    • By kevinohio
