Guest Fox300exchic
I got a new pipe last night!!! Im so excited! An FMF Power Core 4. I know the neighbors hated me last night. HAHA! I rode it around the neighborhood for like an hour. lol :D
Awesome! Did you get the full FMF exaust system or just the silencer? Did you need to rejet your 4-stroke for the exaust? Did you add a K&N air filter or do you not need to do that also? reason i ask i just bought an new LTR 450 and do not know if you need a air filter and jet kit for an after market exaust.
Guest Fox300exchic
Full system. I havent rejetted it yet but they told me if I think I need to...just drill a few holes in the air box. They said that would do about the same as rejetting it. As for the air filter, no I didnt get a new one. Im about due for one anyway.
When you put an exhaust system on your 300ex it goes lean and then when you drill holes in the box it will go even further on the lean side, you really need to put a bigger jet in it for sure
I put a WhiteBros. on my wifes 300ex(fullExhaust sytem) and did the jet kit from K & N and a K& N air filter as well, removed the air box lid and it ripped then i did the after market cdi so it would hit the rev limiter as quick, next to do on the list is to put a 330 kit in it
I realize my first post sounds really dumn now because after picking up my LTR this weekend, I realized that it is fuel injected hahahaha. No rejetting for me. I did read up alittle bit on thumper talk and noticed there are other stuff needed to add a pipe, but after riding it yesterday i am happy with it stock for now.
    • By jay41198
    • By Adamb2025
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
