By oztrax
MAX 4 6X6 2008
By quadcrazy
QUADCRAZY NEEDS YOU!
By DarkRider
Hello there!
I'm new to the forums, but not new to the hobby. Admittedly though, I'm not super mechanically capable. But usually my contributions result in the problems I've attempted to solve via help with the forums and I will post my solutions. Or it I've solved a problem myself, I will post about it and how I solved it.
I've owned a lot of used (ever bought new) ATV's from: Yamaha, Honda, Suzuki, Kawasaki, and Polaris. From sport to 4x4, and have developed all my biased opinions of each brand.
Well that's my intro in a nutshell!
By Myrtsbnye
Hello All,
I have a 1996 Arctic Cat Bearcat 454 and am in a bit of a quandry. I had a bunch of work done on it over the past couple years...new carb, rear brakes, rear axle and bearings. When the rear axle was replaced the shop noticed the left rear hub was stripped. Problem is, the part (1502-178) is no longer available. I've checked junkyards, ebay and other online parts sites across North America and nothing available. Hate to park the bike after all this work just because of a simple hub.
I have two questions...the front hub (part number 1502-177) how much different would it be from the rear hub? This part is readily available. Would the axles be different diameters?
If these are two different parts and we can't make them work, is it possible to take the existing stripped hub and just weld it to the axle? I know it may sound drastic but was wondering if it would not be too crazy?
Thanks for your time
