Fort Worth, Texas (October 29, 2008) – BikeMaster a Leading PowerSports brand released an All-New State-of-the-Art battery Charger for all PowerSport customer needs. The release comes just in time for the cold weather months. The new ChargeMaster 365TD completes a fulline of BikeMaster battery chargers. This exciting product is now available from your local PowerSports dealers, through Tucker Rocky Distributing. Use our dealer locator on our consumer web-site www.PowerSportRider.com, to find the nearest dealer.
Suggested
ChargeMaster 365TD
• Triple mode, 7 stage charger
• Assesses battery connection polarity
• Analyzes and diagnoses battery condition
• Recovers mildly and/or heavily discharged batteries
• Bulk charges batteries quickly
• Monitors voltage retention and battery condition
• Maintains battery with low current if the voltage drops below a set limit
• Extra long cables for ease of use
• Secure-grip alligator clips
• Weatherproof fuse holder
• Permanent connectors with weatherproof cap
• 3 Charge rates: MOTORCYCLES (600ma), CARS /BOATS (3600ma) & BOOST (for AGM batteries and cold weather charging)
• Suitable for AGM batteries that require a higher charge voltage
• Especially useful for charging batteries in freezing weather.
• Backlit LCD display for use in low light conditions
• Displays real-time charging rate, including voltage and amperage
• Designed to be connected for months or even years at a time (winter storage)
battery condition monitor indicates if the battery is able to hold a charge or is in need of replacement.
• Wall bracket and extra long cables for convenient garage use
• The ChargeMaster 365TD is suitable for all 12V battery types up to 130Ah including: Gel, MF and lead acid
Suggested Retail Price $89.95
More...
    • By tds7
    • By WeeBee
    • By C2INS
      Hi everybody!  Just wanted to introduce myself coming from NBTX.  Got some used Honda TRX250's this year and have been hooked on more fixing them up than actual riding right now.  Probably could use some help from the folks here on getting 2 of them in proper running order, but I'm sure I'll have to post that elsewhere!
      But anyways, glad to be here and looking forward to chopping it up with y'all!
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
