its running out a pipe at the bottom of the quad..maybe there is a valve on the gas tank? im not sure how to stop this...I think the previous owner of this quad drained the fuel tank of this quad but now I want to stop the draining
never heard of your quad, I thot this was a joke. there is always a fuel valve easily reached with the left hand while sitting on it. the drainage out of the bottom is likely to be overflow from the carb. send us a pic of this Shineray!
So it is pooring out the bottom of the tank, right? That little nozzle coming out of the tank is the petcock valve. There should be a little lever or something you can turn to a horizontal position. Vertical position is open valve and allows gas to run freely. Horizontal will close it. The hose goes back on the little nipple coming out of the tank.
    • By Topendcol
      Col
    • By Whiterabbit
      New to me Quest 650 with the Rotax engine, auto trans. Looking at the starter solenoid there are the usual wires, Batt+ in and Batt+ out to starter and the 2 lil wires to the ign start button but there is a factory box with 2 lil wires coming out mounted to the frame next to it, one wire is connected to one of the large Batt terminals (12 o-clock position in pic). The other wire from the box is just dangling out in space. I can't find where that loose wire goes and what the **** the lil' box is. 😆 Need some insight please.
    • By Shinerayxy300ste
      I need the wiring diagram for a shineray xy 300stx quad.i got a project from a friend cause he butchered the wiring.and got feed up with it so.i acquired it. Just hard to find any manuals
    • By Mikael
      I recently bought and old Kazuma Dingo 150cc and to begin with it started just fine. Then, for no apparent reason, it wouldn't start. It turns the motor but fuel isn't getting to the spark plug.
      As mentioned in the title I've since replaced the fuel filter, the carburetor, the ignition coil and the spark plug. Fuel comes into the carburetor but seems to go no further. Is it a vacuum problem? Does anyone have a good idea about how I could diagnose the problem? And how to fix it?
      I don't know what year it's from, sorry.
      Sincerely
      Mikael
    • By Hooquad
      Hey, I'm looking for manuals for Shineray XY300STE, Repair and User manuals would be appreciated if someone has those
      Thanks.
