I don't know if it's a common problem or just me, but you might want to check the hose clamps on your rear diff vent.
Mine was leaking oil up around the bellows/accordian, and I noticed the clamps were loose.
Upon further inspection, I found that not only the two connecting the bellows to the hose were loose, but the clamp at the diff vent to the hose was loose too.
Freely spinning clamps can't be doing too much clamping.
I replaced all 3 clamps with some better ones that actually clamp (from O'Reilly). I also went ahead and replaced the splice joint from the hose to the bellows with a slightly bigger one.
I drained and filled the diff after that to be safe. The front is next...
    • By jay41198
    • By LCP92
    • By ButchM
    • By Callaway
