todays HIGH in Bend OR was +3.7f, that's -15.7c. didn't even make the news, cuz of NO power outages, NO traffic accidents, we are prepared for it. What is it with the northeast USA? Those ice storms happen every year and they are never proactive about it. That must be a total pain!
I have my own generator for power outages, 4KW [i doubt it'll start, will have to drain race gas from a
quad] but woodstoves in every building and plenty of firewood! All the high voltage lines are redundant so an outage usually lasts less than a second.
I went to town today and tried to get into my snowsuit; I got it on but I had to pee every ten minutes!hahaha the bibs MUST have shrunk in the dryer last time....yeah that's it! they shrunk!
All the crazy minivan moms were out completely unequipped and unprepared for subzero temps, SLICK roads, and slowed traffic. I thot this one 'humanoid' was trying to crawl right into the bed of my truck! She was so close I could only see the luggage rack....that is SO dense.....her minivan might scratch the paint on my chev K2500. It's up a couple inches and winter ready.
I WONDER WHERE ALL THOSE TOYOTA PRIUS' ARE NOW? I ASSUME THEY ARE ALL BACK IN SUNNY CALIFORNIA CUZ I DID NOT SEE A SINGLE ONE! hahahahaaha yeah a great winter car just like Honda's little 'smurf shoe' man they'll bury ya in that one! spozed to be colder tomorrow.....Look at the bright side...I have fridge space now cuz I can leave the beer on the porch as long as I bring it in before i lock up......
Edited by Raptor8
    • By Adamb2025
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By mikeexplorer
      Here riding options are more limited. These are two small state trails, one is 7.5 miles, the other 7.7 miles. They are about 5 miles apart from each other so we do them both in one day.
      They are nice, but small.
      They are called "Maple Run" and "Burnt Mills" managed by DCNR.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
