By Adamb2025
By davefrombc
Anyone carrying a power box when camping with their ATV? I built a custom one. I used a marine battery box that has 2 50A Anderson Grey connector outputs ( changed one of the greys to a red), an accessory socket and2 USB outlets,and a battery voltmeter .. I added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the output posts.. To charge the 100Ah LiFePO4 battery I put in the box, I added a DC to DC charge adapter that I made input connectors for to allow charging the battery from a vehicle's accessory socket or a solar panel.
It was a fun project.. Besides having a 1,000w power box for 120V ac , USB and 12v accessories using the 10 A socket. I have 50 A Anderson connectors and the 120 A connector to run things like a 12v electric outboard for fishing trips . The LiFePO4 battery only allows a max output of 100A so it can't be used for something like jump starting, but it is half the weight and delivers twice the capacity of a lead acid battery running accessories.. Commercial pow2er boxes don't deliver high draw 12v output to run things like the electric outboards. That's one reason I custom built mine. One box that serves for both camping and fishing.
By mikeexplorer
Here riding options are more limited. These are two small state trails, one is 7.5 miles, the other 7.7 miles. They are about 5 miles apart from each other so we do them both in one day.
They are nice, but small.
They are called "Maple Run" and "Burnt Mills" managed by DCNR.
By dkgg5755
Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
By Need-help-with-quads
