if she peeked at the presents under the tree, perhaps this is a warning!
there isn't a thighmaster among them is there?:laugh:
your future does not bode well....however
DIAMONDS ALWAYS WORK! they'll get you out of nearly anything....
You start buying them that stuff and they will expect something better the next yr!!!:aargh:
Little Story,,,,,,
My EX Wife and I were fighting one yr. at Xmas time ....So just to be an As* I went out and bought her Two Burlap Sack Halves at a Friends Shop.....I wrapped them up and gave them to her for Xmas....She ask what the Hell she was gonna do with those??? I said....Get off your ARSE and Sew them together and you will have a Sack to put all your CHIT in!!!!!!!!! Well,,,,,Im divorced from her now....LMAO!!!!
I am Blessed now though.....My wife and I havent had but a handful or small Arguments in the last 8 yrs....We just Flip each other off in the Hall way now.....:laugh::confused::laugh:
OMG it worked FINALLY! Merry Christmas!!!!!
good luck crawling into THIS doghouse, it's in my back yard! [bring your own sleeping bag]
Edited by Raptor8
a miracle
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
    • By jashadams
      So I installed a new shock on my 125 yesterday sadly it wasn't adjusted right I took it off to adjust it tried to install it again today and it no longer fits I loosened the nuts on the spring again and it still won't fit idk what I'm doing wrong when I try to install it but I'm lost any tips or videos would be great thanks.
