By mikeexplorer
By Maddman200
Who agrees with me that Yamaha atv quailty was one of the best well built quailty machines money could buy, then 2007 came rolling in and they have gone to complete sh**. Cutting corners everywhere they can and made such unreliable machines
By DayBreakJim
20230725_171507.mp4
By Herring
I have an old Yamaha quad that needs replacing. I use it mainly for transporting timber on my own plot of land. What is the general quality of a CF moto? Will they withstand some abuse or should I spend some more and get something Japaneese?
