I just purchased 2 Grizzly 80's for my 8 and 12 year olds for xmas.
They are both new to ATV's and have ridden them twice now and are loving it...
I want to add headlights, and wasn't able to find anything with my feable web search. I know I could figure it out, but figured that someone out there might get me a head start.
Steve H.
First of all they dont come with lights because the Stator will not Support the Watts...
I think you will find that you will have to Replace the Stator with one for RickyStator...I know this is what I have to do with my sons 90......
I have not done any Research on the 80....So dont take any of this for Fact....LOL!!!! But I would do some Research on the Stator for the 80 and how many watts it puts out....
Hmmmm,,,,,,could not find your Stator.....
https://www.rickystator.com/
    • By Louznmemind
    • By Louznmemind
      Can someone please tell me the fill point on the drive axle? '07 Grizzly 350, straight rear drive, not independent. Thanks
      My 2004 Yamaha Grizzly 660 seat is a mess, torn up, cracked, and I have been duct taping it for a while.  I bought new vinyl for $35 and need to do it one day. A new seat used to be well over $250 but now its under $100 so I couldn't resist. I got it on ebay with a 10% off coupon for $85.05 plus tax. https://www.ebay.com/itm/146040022154
      In case anyone is looking for a new seat for their Yamaha Grizzly 😁
      I saw it on Amazon as well for under $100
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
