To the Guy Who Mugged Me Downtown (Downtown, Savannah )
Reply to: [email protected] [ ?]
Date: 2009-01-06, 3:43AM EST
I was the white guy with the black Burrberry jacket that you demanded I hand over shortly after you pulled the knife on me and my girlfriend. You also asked for my girlfriend's purse and earrings. I hope you somehow come across this message. I'd like to apologize.
I didn't expect you to crap your pants when I drew my pistol after you took my jacket. Truth is, I was wearing the jacket for a reason that evening, and it wasn't that cold outside. You see, my girlfriend had just bought me that Kimber 1911 .45 ACP pistol for Christmas, and we had just picked up a shoulder holster for it that evening. Beautiful pistol, eh? It's a very intimidating weapon when pointed at your head, isn't it?
I know it probably wasn't a great deal of fun walking back to wherever you'd come from with that brown sludge flopping about in your pants. I'm sure it was even worse since you also ended up leaving your shoes, cellphone, and wallet with me. I couldn't have you calling up any of your buddies to come help you try to mug us again. I took the liberty of calling your mother, or "Momma" as you had her listed in your cell, and explaining to her your situation. I also bought myself some gas on your card. I gave your shoes to one of the homeless guys over by Vinnie Van Go Go's, along with all of the cash in your wallet, then I threw the wallet itself in a dumpster.
I called a bunch of phone sex numbers from your cell. They'll be on your bill in case you'd like to know which ones. Alltel recently shut down the line, and I've only had the phone for a little over a day now, so I don't know what's going on with that. I hope they haven't permanently cut off your service. I was about to make some threatening phone calls to the DA's office with it. Oh well.
So, about your pants. I know that I was a little rough on you when you did this whole attempted mugging thing, so I'd like to make it up to you. I'm sure you've already washed your pants, so I'd like to help you out. I'd like to reimburse you for the detergent you used on the pants. What brand did you use, and was it liquid or powder? I'd also like to apologize for not killing you and instead making you walk back home humiliated. I'm hoping that you'll reconsider your choice of path in life. Next time you might not be so lucky. If you read this message, email me and we'll do lunch and laundry. Peace!
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
    • By Need-help-with-quads
    • By Mech
      View File TGB Blade-Est 1000 service manual
      Submitter Mech Submitted 09/10/2024 Category Other ATV
