warrior is out yfz project begins!
atvredefined
so the new project begins. i finally got the bike ive always wanted. this is an 04 yfz450. the engine was torn apart due to a sproket bearing siezing thus cracking the case. the guy i bought it from pur chased new cases and everything to rebiuld it but he has to many projects and no time. so i got it for a steal.
it is kinda rough but im gunna get it painted while its gutless. im gunna go for stock this time.:wink:
    • By McG75
      Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds.  It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
    • By DrtyGrlKristin
    • By p5200
      Hello, what is the best method for installing bearings into their race? I've set one in place and tapped it down until it was metal on metal. Is that sufficient? Surely it's not supposed to go into the race until flush? Also. does the coil spring on the seal go into carrier bearing housing not facing out? Thanks! 🙂 Seal goes in until flush correct?
