if u go on any of the oem parts they help u the diagrams r very helpful... im not to sabby with differentials yet still teaching myself things so im not to much help on that side but if u need any help with stuff for ur cat i will be more then happy to help u through it
    • By tepin
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By middlebrookgt
    • By C2INS
