How do these people survive?
ONE
Recently, when I went to McDonald's I saw on the menu that you could have an order of 6, 9 or 12 Chicken McNuggets. I asked for a half dozen nuggets. "We don't have half dozen nuggets," said the teenager at the counter. "You don't?" I replied. "We only have six, nine, or twelve,” as the reply. "So I can't order half dozen nuggets, but I can order six?" "That's right." So I shook my head and ordered six McNuggets
TWO
I was checking out at the local Wal-Mart with just a few items and the lady behind me put her things on the belt close to mine. I picked up one of those "dividers" that they keep by the cash register and placed it between our things so they wouldn't get mixed. After the girl had scanned all of my items, she picked up the "divider", looking it all over for the bar code so she could scan it. Not finding the bar code she said to me, "Do you know how much this is?" I said to her "I've changed my mind; I don't think I'll buy that today." She said
"OK” and I paid her for the things and left. She had no clue to what had just happened.
THREE
A lady at work was seen putting a credit card into her floppy drive and pulling it out very quickly. When I inquired as to what she was doing, she said she was shopping on the Internet and they kept asking for a credit card number, so she was using the ATM "thingy."
FOUR
I recently saw a distraught young lady weeping beside her car. "Do you need some help?" I asked. She replied, "I knew I should have replaced the battery to this remote door unlocker. Now I can't get into my car. Do you think they (pointing to a distant convenience store) would have a battery to fit this?" "Hmmm, I dunno. Do you have an alarm, too?" I asked. "No, just this remote thingy," she answered, handing it and the car keys to me. As I took the key and manually unlocked the door, I replied, "Why don't you drive over there and check about the batteries. It's a long walk."
FIVE
Several years ago, we had an Intern who was none too swift. One day she was typing and turned to a secretary and said, "I'm almost out of typing paper. What do I do?" "Just use copier machine paper," the secretary told her. With that, the intern took her last remaining blank piece of paper, put it on the photocopier and proceeded to make five "blank" copies.
SIX
I was in a car dealership a while ago, when a large motor home was towed into the garage. The front of the vehicle was in dire need of repair and the whole thing generally looked like an extra in "Twister." I asked the manager what had happened. He told me that the driver had set the "cruise control" and then went in the back to make a sandwich.
SEVEN
My neighbor works in the operations department in the central office of a large bank. Employees in the field call him when they have problems with their computers. One night he got a call from a woman in one of the branch banks who had this question: "I've got smoke coming from the back of my terminal. Do you guys have a fire downtown?"
EIGHT
Police in Radnor , Pa , interrogated a suspect by placing a metal colander on his head and connecting it with wires to a photocopy machine. The message "He's lying" was placed in the copier, and police pressed the copy button each time they thought the suspect wasn't telling the truth. Believing the "lie detector" was working, the suspect confessed.
NINE
A mother calls 911 very worried asking the dispatcher if she needs to take her kid to the emergency room, the kid was eating ants. The dispatcher tells her to give the kid some Benadryl and it should be fine, the mother says, I just gave him some ant killer..... Dispatcher: Rush him in to emergency room!
Life is tough. It's tougher if you're stupid
  • 4 years later...
    • By shorty
      I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
      I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
    • By Eric C
      I have looked at every thread I feel like, but with no resolution. Its always the same with a no spark issue:
      Replaced CDI,
      Replaced Pickup Coil (Pulsar)
      Good continuity from CDI to green white wire at ignition coil.
      No Pulse at ignition coil on the green white wire. (testing with test light on Pos of battery.)
      Good 12+ V on the hot side of ignition coil.
      I swapped the wires around on the Pulsar.
      The grounds seem to be good for the blk/y wires throughout bike.
      Brand new battery.
      Brand new stator and Pulsar
      Tried 2 new CDIs
      Brand new rectifier
      I get about 300 Micro A/C volts across the two wires on Pulsar when cranking.
      I am currently cleaning the connections on the rectifier because they were burnt. I am not even sure if it makes a difference because I am told that doesn't produce spark anyway and is only for charging system.
      The fly wheel looks OK, is the pulsar supposed to be connected in the direction with the metal "Button" facing towards the flywheel?
      My bike is a 1995 bayou 300, but I seem to come across same issues on web but no resolution on these things.
    • By SnowmanTX
      Hello!
      First time poster here, looking for help. This will be long, but I want to give you the whole story.  I'm very confused because I am a fairly experienced mechanic but must be missing something. A friend who is not mechanical brought me a 2003 Eiger 400 automatic that didn't run. A quick inspection revealed that the motor was seized. I pulled the top end and found the cylinder and piston rings were rusted together from the machine having been submerged at some point and then left to sit for several years.
      I put in a new piston and cylinder and checked the valve lash. Compression test today was 150 psi.  Replaced the corroded vacuum petcock with a Yamaha petcock, cleaned the fuel tank out, and replaced all the fuel lines. Replaced the badly corroded carburetor with an Amazon aftermarket model (with good reviews) and it wouldn't start. Found that there was no spark so I substituted an Amazon 4-pin CDI box and found that I now have good spark. It still wouldn't start so I used a little starting fluid and it fired right up for about 3 seconds.
      Now, after cleaning and checking out the new carburetor, I have found that when it cranks and fires, the engine actually kicks backwards momentarily and then resumes cranking. It is acting like the spark is way advanced and it is firing before TDC. I know that it is turning backwards momentarily because I still have the recoil off and I can see the starter cup rotating and then literally stopping momentarily when it fires. I've had the flywheel off to check the magnets and the woodruff key. The flywheel does not have the exposed magnets, but the fully enclosed magnets like the replacement RMStator flywheel. The woodruff key was in perfect condition. The pickup coil resistance test was good.
      Since it seems like a timing issue, I pulled the cylinder head off again and double-checked the timing. It did appear that the timing marks were off by one tooth, so I corrected that and thought that I had found the problem. Unfortunately, it still does the same thing...It will crank just fine, but won’t start, and kicks backwards when it fires whether I use starting fluid or not.
      Since the timing is not adjustable on this machine, I’m wondering if the factory CDI circuitry incorporates any type of variable timing feature that is dependent on RPM?  That is about the only thing I can think of.
      I've read other threads that discuss this "kickback" symptom and the usual culprits are weak battery or a too lean condition causing preignition. I've installed (and charged) a new battery and triple-checked both carburetors...the original one that I completely cleaned, and the Amazon replacement.  Same response with both carbs, which leads me back to questioning the CDI.
      Any body else run into this?
      Thank in advance for your help.
    • By Krazo
      as title states, what are these wires?   I took off the rear plastic, and right behind the brake light, these wires are all disconnected.  Not sure what they go to.  Aside from my current issue of what appears to be a bad coil (replacement ordered) the atv has run fine for me.  I just bought it this past winter and spent time replacing front end components but motor has run fine until the this past weekend.  By the looks of these wires they've been unplugged a while.  only thing I can think of is they're for trailer lights maybe....?  but i really don't know.
