ok guys need help tryin to figure this one out, pics of the bike are on the rebuild thread, but i just realized that its a four stroke and not a two stroke. Did they make 250's in four stroke form or is ithe bike a 230? (i was told by several people that its a 250 but still not sure)
Yes they made a 250 Quadsport, but the 250 Quadsport was first. The 250 Quadsport was to compete against the Honda 250X and Kawasaki Mojave. Both Quadsports were 4 strokes not to be confused with the 250 Quadracer, witch is a 2 stroke.
It appears what you have is a LT230 Quadsport. The LT230 were from the 85-88 best I can find but I really thought that they started earlier. The 250 Quadsports were made in the 89-90. They stopped making sport quads for awhile after 1992 which was the last year for the LT250R.
      OK, so I'm a boxing fan...anyone watch last night's fight between Manny Pacquiao & Ricky Hatton?
      The PacMan is just too fast and too accurate. Floyd Mayweather just announced yesterday that he's coming out of retirement to fight Marquez in July. Maybe we'll get a December fight between Pretty Boy and the PacMan?
      So, Manny has convincingly beaten up DeLaHoya (just announced his retirement from boxing) and now Hatton...
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By Atomusthenes
