  • Join Today, It's Simple and FREE!
Delvis34
1986 Honda TRX 70 Rear End Disassenbly
does anyone know how to take apart the rear end of a 1986 Honda TRX 70 fourwheeler . I need to get the axle and brake system of so i can get the frame powder coated . I would greatly appreciate any help with this . My boys wont stop asking me when the fourwheeler is going to be done
Share this post
Link to post
If you can't figure it out by looking at it, you should get a manual. If you want, you can take some detailed pics of the rear end, specifically the part where the swingarm bolts to the frame. Post them here and I/we can try to give you some advice.
Share this post
Link to post
Undo the 17mm brake side axle nut ,(Right side while facing bars) remove the nut, then the washer, the wheel, then the depending on the unit the spacer, and "o"ring. (on some later units the spacer is held in by the outer brake shield) in either case, remove the brake shield (Three 10mm bolts) All items should slide off fairly easily from the shaft, there are no hidden clips that I know of. The brakes should now be exposed. if you are un-sure of what to do from this point, be sure to take plenty of pictures, as brakes are a handy thing to have.
Jim
Share this post
Link to post
Jim
Great explanation!
*Moved this thread into the Honda technical forum and also change the title to: 1986 Honda TRX 70 Rear End Disassenbly
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
    • By Jeff Taylor
      I bought a roughish Honda rancher TRX350TM3 and I am having trouble locating the vin number - I would like know year and specs as is it rough , it runs but has multiple little issues ( choke cable seems frozen , carb has sticky or ill adjusted float and leaks gas from bottom of carb , shut off valve needs new o-ring to stop leaking , ect)  just age and lack of maintenance issues , but I need to know what it is to get correct specs … I was told there would be a tag on front end of frame but I don't see one . Any help would be greatly appreciated .
    • By JStricker
      I'm in need of a replacement engine for my '04 400ex. Can anyone help or at least give me some direction.
    • By CHomp DICKENS
      I broke the axle in my Honda foreman 4×4 when I went to change the axle so.done had weld it before and don't know how to git the gear off  seems the axle should slide out of the gear  not this one how do I remove the gear from broke  axle
    • By GERONAMO308
      Hi all am wondering if anyone has wrecked a 1992 quad runner, an has rear plastics available for it?.
      Am hoping for red, although will take any colour if is in Perth Western Australia.
      Any advice is greatly appreciated
    • By 4tracker
      Advice/recommendation on a set of lite rear UTV tires 26x11-12 needed for mainly very soft deep sand 65%, 15% gravel rd., 10% hard pack,  5% paved roads. 5% mud. All the reviews mention mainly mud lites, and very little sand lite tire brands! Looking for a tire that's lite but will dig well, reducing motor clutch overworking while slipping/spinning in lite sand. Appreciate any advice, Thanks, Steve
  • Similar Tagged Content
    • By Anthony Marceau
      Hi everyone! I have a 1986 yamaha moto4 200 that's been sitting for a while! Cleaned the carb, replaced engine oil, put fresh gas in it. Got it running and went for a ride! It was running great just a little backfire once in a while! I barely made it home on the way back and now the bike won't run at all since then! It will start if I give a little bit of throttle but dies instantly as soon as I let go off the throttle! And even if I try to rev it up it'll sound like its not getting enough gas.. it revs up a couple hundred rpm's and backfires through the carb.. it almost sounds as if I was trying to take off from zero in 5th gear! Nothing is seized though! I dissasembled the head and the piston and cylinder are fine! Rebuilt the carb, replaced the ignition source coil.. I don't know what to do anymore.. compression test shows 90 psi Specs are 128 psi but i'm not sure if I trust my compression tester.. any ideas? Thanks!!
    • By Kyboy
      Iam looking for help seperating the rear brake drum and the cover. Any suggestions would be greatly appreciate
    • By chuckcnm
      Hi, just picked up a MOTO 4 YFM255 and want to replace the rear brake pads. How do I get to the back. Guessing I need to remove the brake disk, question any easy way to do this?
    • By sloundez
      Does anyone out there know where I can get a functional pair of wheel cylinders for subject ATV? Any suggestions welcomed. Thanks
