Background,
Any Ideas?
Picked up a 86’ LT 185 for $10 in trade value(my items only cost me $10)
recoil only , I pull the recoil and it won’t move , so I took it off , I can spin the crank there one full turn left then it locks up , and one full turn back to the right and it locks up
pulled the plug , the piston is moving up n down , both valves are moving(pulled the caps)
pulled the clutch off , oil pump gear , and it still locks up after one turn
any ideas or where to go from here would be greatly appreciated
im a 2 stroke guy so this all is new to me
Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
