:aargh:My Outlaw is leaking oil out off the seem in the engine block just above the rear oil filter area and possible another spot in that seem. Anyone else had this problem? What would cause this? I thought KTM was suppose to be a good engine, thats the only reason I risk getting a polaris.
Edited by verve
KTM does make a great product, they always have. However, no one is perfect. Your oil leak is most likely just a bad gasket, but you could very well have a crack in the case from a rock or something. Clean it up really well and give the motor a good once over. Unfortunately, you will most likely need to split the cases either way and fix the problem. On the plus side, you could use this as an opportunity to do some mods while things are apart.
    • By noticon75
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By toe420
