I need help with the Right Word
By OldATVowner
By afterdinnerspeaker
Hi Everyone!
Recently, I could no longer start my Arctic Cat using the green starter button.
Initially, the response was intermittant (sometimes it would start and other times in wouldn't).
Finally, I get no response or sound by pressing the green button.
I'm trying desperately to trace the wires from the green button but can't seem to follow.
I took the button apart and cleaned the contacts but no difference (yet my instruments indicate contacts are OK).
I inserted an image to show the wiring colors going into the green switch.
I'm still able to start the machine by using a long screwdriver to short the starter.
I'm hoping someone can help me find a possible break in the wiring or any other cause.
Many thanks in advance to anyone who can help me!
Jerry
By jatho
Does anyone know what year they stopped producing the King Quad 300? - particularly in Australia and New Zealand
What were the design changes?
By getdirty
Thanks in advance, 06 LT-R450, will start and immediately shut down will not idle at all. Fuel pressure is good, injector good, spark is good, also checked the TPS and it is good. While messing with the IAP checking voltage and such disconnected the vacuum line from IAP to the throttle body and it will start and idle just fine, any throttle input and it will spit and sputter and eventually die. reconnecting the vacuum line while it is idling will kill it. I swapped another IAP with a known working one and had the same effect. What would cause this? Does anyone have some suggestions on where to go from here?
By TwistingDicksThrottles
I obtained one from a cousin with no title or knowledge of the year. Was it 200- 2003 only?
