Join Today, It's Simple and FREE!
Sign in to follow this
Followers
0
By chem3233
I have a 1998 yamaha grizzly 600 4x4 I have put back to life but as soon as I had all the bugs out it blew the special "L" plug out. What causes this? Is there something special I have to do to replace this?
By Wesley Floyd
Hey guys, Thanks for looking at my post. I haven't had a lot of experience with problems like this before, so I'm a little bit at a loss. The Quad was really hard to shift, (the dirty carb leaking gas making it idle high didn't help either). The only Idea I have would be is that the torsion spring is worn out, and that there is a normal parameter for how much it should move when those two arms of the shift shaft assembly spread apart. That's my thought. Maybe someone who has more knowledge then me can let me know if i'm on the right track 😀
By Alan Callison
OK everybody,I need some help here please. My 4 wheeler has got a bad wheel bearing I discovered while starting a brake job. Its on the left side. I've never done one and I need some knowledge how to go about it. Am I to understand I need to pull the whole axle out to do it. I've done it once on a car about 30 years ago,lol. I keep looking around for a repair manual but they're hard to find without having to buy it. I looked here on this site but apparently Im too junior a member to be able to download one right now.Bummer! One other question if I may.When I pulled the drum off the spindle a torrent of water poured out,the brake shoes were covered in mud along with everything else. I mean the drum had alot of water in it. The shoes were so locked up after I removed the springs I tried to rotate one of the shoes and it wasn't easy at all. I noticed whoever had the machine before myself had laid a bead of RTV around the back plate but apparently it didn't work. Isn't there some kind of gasket for this purpose. I saw it calls for a dust shield but surely this wont keep the brakes dry or will it. Thanks everybody.
By Wolds Alpacas
I have a Yamaha YFM225 which sounds really noisy exhaust wise. It had no baffle so I bought and installed that but it seemed to make no difference. There are no leaks from the manifold or exhaust but the damm thing just sounds so loud !
By Rick Shropshire
Here's some pics from within the last month. Rather than build a frame and body from scratch, I drove to Kansas and bought a rust bucket G2 for $40 minus batteries. I've since cut it up in prep for the 1100cc v-twin shaft drive engine. I've included a picture of the of the latest mock-up. Im extending the frame and wheel base 12 more inches and widening the body by 12 more inches as well. I have on order a right side axle shaft and housing for the left side of my ATV rear end. This will widen the axle by about 12 inches. I will be eliminating the front a-arms and replacing with straight pipe from knuckle to knuckle. I'll post more as it progresses.
Similar Tagged Content
