By Malta54
I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
Sparking Plug
Fuel Injector
Fuel Pump
Fuel Filter
Fuel Valve
Fuel lines
Power Control Module
The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
Would greatly appreciate any assistance.
Thanks in advance.
By quadcrazy
QUADCRAZY NEEDS YOU!
By Zachary
Hey guys I have a 99 xpress 300 and I'm having an issue, I rebuilt the engine and it will only start when I put my han over the intake on the car (when I manually choke it), I am not very familiar with plunger chokes.could some one help me understand how this choke is supposed to work and maybe how to ajust it so it works, thanks!
By jmeier1981
Ok guys Ive got a few more for ya.
TIRES:
Ive thought about getting new rubber for the wheeler it has some half worn down 25" Kenda executioners on it and Id like to get something that maybe rides a little better and does as good or better in the mud if thats an option. Any tire model suggestions? Also I would like to go to a 27" or mayb e even a 28" are there any disadvantages to doing this would I have to change anything on the wheeler to make up for the larger tires? Ive had a couple people tell me that they would be hard on the clutch.
WHEELS:
Ive seen some really nice looking aluminums but not sure they are tough enough to handle trail riding...Are they??? If so what would you reccommend, id like a little off set to give it a slightly wider stance and better stability but a buddy has a set of ITP wheels and the rear is offset a lot compared to the frnt and it looks great but hes constantly getting the back wheels hung up on trails
SNORKEL:
I see that the airbox on the brute is where a normal wheelers gas cap would be, so that being said am I good to go with water as long as it doesnt go over that point os is it not sealed up to the box? Also how about the belt and it staying dry, do I need to do anything to ensure that it doesnt get soaked and leave me stranded.
Oh by the way I love this thing the more I ride it the more Im glad I went with the powerhouse, Ive run with a couple polaris 500s 700s a grizzly 660, and 700 and a couple rincon 680s that were built and they cant touch my stock 750, although she likes her gas thats for sure i got about 50miles and Im needing a refill
Create an account
Register a new accountSign in
Sign In Now
