Create an account
Register a new account
Sign in
Sign In Now
      QUADCRAZY NEEDS YOU!
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
    • By Hagbard
      Looking for a DRIVE SPROCKET RETAINER PLATE for a 1987 LT230E (P/N 24751-35B01)? Good luck.
      Believe me I searched high and low, including contacting two OEM suppliers in Japan. No dice.
      Ran into this problem myself. The part is no longer available, unless you get SUPER lucky on eBay.
      My solution was to use the identical part from the newer ones, but you have to switch out the bearing and spacer bushing as well. Basically I took the retainer plate (46) and spacer bushing( 55) from a 160 motor I have for parts, and bought a new 6206 bearing which is the right size to match part (40) https://www.amazon.com/Bearing-30x62x16.../dp/B07XJ7H2VJ There's also a difference in thickness between the sprockets, so I added a couple 14ga. bushings as spacers
      So, referencing this parts diagram, you need to get everything from the bearing (40) on out. So, parts 40 (BEARING 09262-30084), 46 (RETAINER 24751-35B10), 47 (OIL SEAL 09283-38017), 48 (O RING 09280-70009), 54 (O RING 09280-21008), 55 (SPACER 27531-35B10), and 59 (PLATE, FRONT CHAIN GUIDE 27641-35B00).
      https://www.babbittsonline.com/.../50d08495f.../transmission
      If you need me to walk you through any of it I'd be happy to help.
