      QUADCRAZY NEEDS YOU!
    • By mikeexplorer
    • By Topendcol
      Col
    • By DayBreakJim
      20230725_171507.mp4
    • By Frank Angerano
      This is a good question asked by @Johnny Chancellor. I put it in a new topic so it does not get lost.  We all know we need a cdi box but I bet a lot of the members here don’t know how it works. This is a good explanation of a cdi box including what it does, how it works and what “cdi” stands for.
      Ive posted two links here. Feel free to add to the list!
      https://www.elprocus.com/capacitor-discharge-ignition-cdi-system-working/
      https://en.wikipedia.org/wiki/Capacitor_discharge_ignition
