By davefrombc
Anyone carrying a power box when camping with their ATV? I built a custom one. I used a marine battery box that has 2 50A Anderson Grey connector outputs ( changed one of the greys to a red), an accessory socket and2 USB outlets,and a battery voltmeter .. I added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the output posts.. To charge the 100Ah LiFePO4 battery I put in the box, I added a DC to DC charge adapter that I made input connectors for to allow charging the battery from a vehicle's accessory socket or a solar panel.
It was a fun project.. Besides having a 1,000w power box for 120V ac , USB and 12v accessories using the 10 A socket. I have 50 A Anderson connectors and the 120 A connector to run things like a 12v electric outboard for fishing trips . The LiFePO4 battery only allows a max output of 100A so it can't be used for something like jump starting, but it is half the weight and delivers twice the capacity of a lead acid battery running accessories.. Commercial pow2er boxes don't deliver high draw 12v output to run things like the electric outboards. That's one reason I custom built mine. One box that serves for both camping and fishing.
By Chucksta
Any ideas?
By anthonyd256
I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
By Suzukiquad
Are there any good mods for adding a radio, or Bluetooth speaker that's kid friendly? My son thinks he needs music while riding around.
