Alright , I just bartered my way into two of these dinosaurs. One runs , the other...not yet. The one that runs has a valve type leaver on the head. Is that a decompression valve?
And how should it work? Also when it runs it tends to studder or miss during accelerator.?
If anyone has parts for these, let me know @ [email protected]
I am looking for :axle, exhaust, service manuals, wiring etc..
Thanks Rob in Kalamazoo, mi.
A picture would help identify you mystery device. Any manual decompression valve I have seen is operated by a small lever, on the handebars. You pull in the lever, give it a good kick and then release the lever. I have never seen a decomp on a motor that small before though. Always a good idea to take a look inside the carb, if it had been sitting for a long while it will need a good cleaning. Good old ebay is my favorite place to buy parts, just make sure to only buy from users with a good seller rating. You can find manuals there too.
    • By LCP92
    • By DexKing
    • By shorty
      I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
    • By PolarisRich
      I've never done this before but after reading a few thread I decided to check my valves for the first time and to my surprise it was much easier than I thought.
      My bike is a 2005 Sp 500 HO.
      I first pulled the seat and the right side panel off, and that's it! It wasn't too bad to get at.
      Next I pulled the spark plug out and removed both the head cover ( 8-8mm bolts)
      [ATTACH]1021[/ATTACH]
      then the side cam cover (5-8mm bolts).
      [ATTACH]1023[/ATTACH]
      Also remove the plug in the recoil cover (14mm bolt) to see the timming marks.
      [ATTACH]1022[/ATTACH]
      Next I turned the engine over with the pull cord untill it was at TDC of the compression stroke.
      The best was to tell that your at TDC of the compression stroke is to rotate the engine until the
      timing marks are parallel to rocker cover gasket surface.
      The cam sprocket locating pin will be facing upward directly in line with the crankshaft to camshaft center line.
      Now fine adjust by looking into the timing hole in the recoil cover and line up the upside down "T" on
      the flywheel into the center of the hole.
      Now using a feeler gauge, slide the .006" (.15mm)blade between the top of the valve and the bottom of the adjuster and adjust accordingly
      [ATTACH]1024[/ATTACH]
      [ATTACH]1025[/ATTACH]
      To adjust, Loosen the locknut (10mm) and check clearance with a feeler guage. Clearance should be .006" (.15mm) for both, intake and exhaust valves. Turn the adjuster with a stubby flat blade screwdriver untill the proper clearance is achieved then tighten the locknut (5.8-7.2 ft. lbs) while holding the adjuster in place with the screwdriver. Re-check the clearance with the feeler guage one last time and re-assemble the covers (72 in.lbs) and plugs.
      The only thing that i noticed was that I had to clean and silicone the side cam cover other than that I found the whole process rather simple.
      I'd give it a 4 out of 10 on the skill level scale.
      I hope this helps!
      Thanks Rich
