A little help with handlebars please
I'm needing some new handlebars since I rolled my 2007 DVX/LTZ400 last December.I was hoping I could get some good ideas/info from others who's bought aftermarket bars.I'm 6 feet tall and the factory bars have always felt too low.From what I've read the factory bars are the CR Hi bend;is that true?What real benefits do the oversized 1 1/8" bars give?Which has a better vibration dampening effect;steel or aluminum?Do the antivibe steering stems really do much compared to stock?Would I be better off getting a steering damper and leaving the stock stem alone?I do all types of riding;everything from woods/trail to sand dune&mud running.I've been using some padded palm gloves to reduce the vibe it has already.Thanks in advance
Try a stick style stabilizer. Streamline makes the one I use. Makes a WORLD of difference and it is a cheap easy to install fix.
Streamline Billetanium Stabilizer - Bars & Controls Online at MotoSport
The problem with the real strong aftermarket bars(even though I run them) is if you take a bad roll, something has to bend and it usually the stem which is next in line. There is an adapter that you connect to your existing bar claps. It then allows you to run the oversized bars, which do help with the vibration. The clamp actually raises your bars almost on inch.
Update-I ended up getting a set of Renthal standard size(7/8") oem bend handlebars and some Smith Optics brand grips from a local dealer.It feels different from stock;but I'm still not 100% comfy.I'm really thinkin about trying the Rox riser.Here's a link ATV Handlebar Risers I also recently got a new front bumper,cooler rack,nerf bars,steering stabilizer(Streamline-thanks 'Bot),hour meter,and tether kill switch.I also finally got a new digital camera so I'll be able to get some pics up soon I hope.I almost forgot-if anyone is needing/wanting new handlebars;Renthal has a deal goin on if you order/purchase new Renthal bars(fat or skinny) by August 1st and go on their website you get a pair of limited edition bar pads FREE
Edited by dirtdevil96
forgot something
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By newguy024
      I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
