Can anyone tell me which crank and rod to go with on my 05 yfz 450. Rod is bad in mine and want to upgrade to 06 but I don't want OEM. Thinking of WR crank with falicon rod. Is this a good decision?
Hot Rods is made by Wiseco, definately a quality product. By the way, I merged this thread into your original crankshaft thread since they were so similar, and added the year make and model to the title, please remember to add that info to the title when you start a new thread, it helps direct web searches to our site.
Edited by DirtDemon
I"ll let you know how it turns out. I have decided to go with the WR crank and falicon "knife" rod. the crank is one pound lighter than oem and I called a tech with hot rod cranks and he told me that theirs are a little heavier than oem. I know of two other yfz's with the same crank and rod that i'm getting and they both rev like two strokes. I'll definitely know how it turns out.
    • By toe420
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
    • By sunn
      Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
      Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted.  The atv started, but then died a couple times after repeated attempts.  But when run awhile everything was ok.  Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
      Is this typical of a failing fuel pump?
      I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM.  Just had all covers off so looks really easy to replace.
      Any ideas?
