  • 6 months later...
There should be 4 bolts on top of the rear swing arm loosen all 4 then there are 2 studs with nuts on them on the back of the swingarm if you loosen them it will then allow you to pull the axle back towards you wich will tighten the chain, once you have it adjusted to where you want it just tighten the 4 bolts on top of the swingarm and you are ready to ride. Really it is pretty simple you just want to make sure when loosening the nuts on the 2 studs you do so equally so that the axle is not offset to one side anyhow hope this helps!
    • By Yamahahahaha
    • By Norseman69
      Hi. I just bought an lt230 1993.  Ive started buying parts for a full rebuild.  But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed.    I was wondering if anyone have one and Could measure how far out the pegs are.  Like the peg the brake is put on and then peg outside of it.  And the one lower down.  So i can recreate them.
    • By Heymax
      I bought a 2003 Bombardier Quest XT 650
