Could be rings, valves, or a head gasket. It is a bit odd that you would be burning oil in a quad that is that new. Have you been doing services regularly? If so, and it is still under warranty, I would let Yamaha deal with it.
i would first check oil level
you need to run quad for a 3 minutes and let sit for 2 minutes before checking stick
excsessive on off throttle use can cause fuel to run through rings and elevating level if so replace oil
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By middlebrookgt
    • By C2INS
      Does anyone know if they're interchangeable?  I have a 2002 TRX20TE and 2007 TRX250TE, so getting to a set of common engine parts would be ideal.
    • By mikeexplorer
