Cleaned carb on my 300 fourtrax over weekend. Cannot seem to get (mid throttle) stall out of it. Does pilot adjustment mean that much in regular elevation (oklahoma) i set it where it was (2 1/4) turns out
* Adjusted thread title to include model and make.
What year is this quad?
    • By quadnut20
      Went for a solo ride up at Rollins Pass Colorado !! Elevation is around 10'000 ft 11'500 at the top but the snow stopped me but was still fun !!
    • By Adamb2025
    • By T37Mark
    • By 97kingquad
