Ask Mikey Technical Questions
Due to his disgruntled behavior Mikey is permanently locked away in the ATVR garage, but he does have occasional Internet access to answer your tech questions.Each month we receive an overwhelming flow of technical questions from our readers. Everyone at ATVR including the night janitor carries an extremely heavy workload so as a last resort we were forced to put Mike Newsom in charge of answering your questions. Mikey is one of the most talented mechanics we know, but it's his off-the-wall remarks and repulsive attitude that keep him locked away in the garage. If you dare to bear his response, send your questions to [email protected]. We promise not to let Mikey use your name and embarrass you in front of your buddies.
Photo Gallery: Ask Mikey Technical Questions - ATV Rider Magazine
Read More | Digg It | Add to del.icio.us
More...
    • By smallmotor2002
      Hello everyone.
      I'm working on a 2014 Yamaha 700 Grizzly and having no luck accessing the diagnostic mode on the display. I have tried with the fuel pump connector plugged and unplugged, and select and reset buttons depressed simultaneously for up to 30 seconds with no luck.
      I could sure use some assistance if anyone has any tips on this
    • By jmeier1981
      Ok guys Ive got a few more for ya.
      TIRES:
      Ive thought about getting new rubber for the wheeler it has some half worn down 25" Kenda executioners on it and Id like to get something that maybe rides a little better and does as good or better in the mud if thats an option. Any tire model suggestions? Also I would like to go to a 27" or mayb e even a 28" are there any disadvantages to doing this would I have to change anything on the wheeler to make up for the larger tires? Ive had a couple people tell me that they would be hard on the clutch.
      WHEELS:
      Ive seen some really nice looking aluminums but not sure they are tough enough to handle trail riding...Are they??? If so what would you reccommend, id like a little off set to give it a slightly wider stance and better stability but a buddy has a set of ITP wheels and the rear is offset a lot compared to the frnt and it looks great but hes constantly getting the back wheels hung up on trails
      SNORKEL:
      I see that the airbox on the brute is where a normal wheelers gas cap would be, so that being said am I good to go with water as long as it doesnt go over that point os is it not sealed up to the box? Also how about the belt and it staying dry, do I need to do anything to ensure that it doesnt get soaked and leave me stranded.
      Oh by the way I love this thing the more I ride it the more Im glad I went with the powerhouse, Ive run with a couple polaris 500s 700s a grizzly 660, and 700 and a couple rincon 680s that were built and they cant touch my stock 750, although she likes her gas thats for sure i got about 50miles and Im needing a refill
    • By p5200
      Hello, what is the best method for installing bearings into their race? I've set one in place and tapped it down until it was metal on metal. Is that sufficient? Surely it's not supposed to go into the race until flush? Also. does the coil spring on the seal go into carrier bearing housing not facing out? Thanks! 🙂 Seal goes in until flush correct?
      Im finishing up on the Big Bear, just tying up some loose ends and its done.
      My next project I actually bought first, but the Big Bear seemed like it was more challenging so tackled it first. Now looking the Eiger over im not so Sure.
      I bought this Suzuki Eiger, almost a year ago, rear wheels locked up, but it ran fairly well. It was so bad that it took 3 Big Guys to get it on my trailer. All the parts were there it ran. He wanted 600.00 and I offered him 400.00. a plus it had the original Kei Hin carb on it.
      You might ask, why would you want something so ugly, it is often referred to as the ugly sister to the King Quad. I actually like the Eiger I have this one and also a 2007. I have riden them before, they are strong a true beast, I am a fairly Big Guy 6' 3" 195 pds, and it fits me good, but what I really like is the wide foot print and low center of gravity , not so easy to turn over.
      So I get it home and I don't have 3 big guys to help me get it off my trailer, but I do have a John Deere, hooked it up and drug it off the trailer,an afterthought I should have used a couple of furniture moving dolly's under the rear wheels, oh well. Maybe I didn't ruin the already stuck rear end or transmission I was sure which, I was fairly sure it wasn't locked brake drums, after all that they should have popped free.
       This is what I have done so far. It's off the trailer I took the drive shaft bolts loose, they were tight, had to get a 3 foot cheater, I thought they were going to break. Got them out and now I can roll it around. I checked the shifter, this is a manual shift Eiger LTF400F. Foot shifter moved didn't seem to be going to any gear, but it was hard to tell, the shifter on the tank which has Low, High, and Reverse did not move. I took it apart and oiled it up good still wouldn't move. Thought the cable was stuck so I unhooked it from the linkage and cable moved freely. Looked at the linkage closely and it was stuck. I tapped it lightly, very lightly , with small hammer and it freed up kind of, but still stiff. I could tell this side cover had been off before and put back very sloppily. This is kind of where i left off except the plastics are all off, you might have seen me working on them in another post. Nothing I have done so far has helped, my next step was to take the side cover off the engine to see what's going on in there, but installing my Granite counter top, numerous honeydews, and the big bear kind of slowed down my progress. I did determine that it wasn't the rear end, that's actually what I thought it was going to be. If anyone has any ideas, they would be appreciated.
    • By gohndd
      Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
