By oztrax
MAX 4 6X6 2008
By quadcrazy
Best ATV for Older Riders
Polaris Sportsman 570 EPS
Best Reliable ATV for Seniors
Honda FourTrax Rancher EPS
Best Features
Best Premium Comfort ATV
Can-Am Outlander MAX
Standout Comfort Features
Best ATV for Easy Handling
Suzuki KingQuad 500AXi
Why Older Riders Like It
Yamaha Grizzly 700 EPS
Best Features
Arctic Cat Alterra 600 TRV
Key Advantages
Electric Power Steering (EPS)
Automatic Transmission
Lower Seat Height
Two-Up Models
Hand Warmers and Heated Grips
Adjustable Suspension
Buying Too Much Power
Ignoring EPS
Choosing Aggressive Tires
For most mature riders:
Final Thoughts
By Callaway
By BillR94
Thank you for your time
Bill
By Sha35297
I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
