I just picked up a nice 1996 suzuki King quad 300 4x4 only 700 miles on it and i stole it cheap from my boss at work. he does'nt have a service manual or owners manual for it and i want to change the fluilds on the quad..can someone tell me where fill and drain plugs are and the Oil filter...i found a fill on the rear trans houseing that says 10W40 on the fill cap and a drain plug on the bottom does the engine oil and rear casing run the same oil?And does it have a gas filter and where the heck is it?? Thanks MUDDIE49:confused:
Edited by MUDDIE49
The oil should be the same for the motor and tranny. I believe there is a small filter in that carb, but I'm not 100% sure. That quad has the shifters in the middle, right?
* Adjusted your thread title to include your atv info.
Yes i did...the oil filter is in front of the rear wheel on the right side...oil 3.7 quarts is in the rear.....fill plugs rear of trans, plugs below transer case.....Front caseing takes 80w90 GLF-5 fluid.....I hav'nt found the fuel filter and not even sure if theres ones...i'm thinking screens in the fuel shutoff valves,I'll take it apart and see. MUDDIE49:wink:
    • By docdoug72
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By Thekevinjb
      thanks
