i am trying to learn to ride wheelies on a raptor 660 and i could use some tips if you have any at all that could help me the problem i am having is keeping the front up thank you all for any input you give
i dont have a grab bar on this one but i have tryed in that postition and its more better for me im just worried ill toss it back to far and bam there goes my exaust i have some vids on my profile of me trying then both sitting down and knee in the seat
The big Raptors are the most wheelie happy machines I have ever ridden, so you have the right quad for it. Just keep practicing, you will get it, it is just a matter of feeling out the balance of the machine like Bot told you.
GET A GRAB BAR! When you are learning wheelies it's almost a gaurantee that you will go back far enough to hit it a few times. It's even more likely when you decide to learn to shift with the front end up. Every quad is different when learning and I agree with everyone else. Practice, Practice, Practice!
    • By TomJulio
    • By Gtc4d
      Thanks.
      Todd
    • By ButchM
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
