By quadcrazy
Trail System Deep Dive
Final Thoughts
Visit Pine Mountain ATV Park
By Zrach
I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
Note: This modification compromises the factory “no-start” circuits.
On some malfunctioning CDI units the internally damaged circuitry is only partial.
Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
The Modification
See the second diagram attached below for the wiring specifics.
The Result:
The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
⚠️ IMPORTANT SAFETY WARNING ⚠️
Please be aware that this modification compromises the factory safety "no-start" circuits.
The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
Faulty CDI Workaround.pdf
By Cramer88
out of the blue my vinson wouldn't shift into park and when I am in H or L and go past a slow pace (maybe in 2nd gear) it grinds and Low grinds even louder. It sounds as though it may be in the rear diff. I have not tore into the rear end or anything yet. I was looking for advice before tearing it apart. Reverse has no grinding at all and H gear doesn't grind until you get moving past a walking pace. L grinds as soon as it moves. It shifts into gear smoothly and 4wd works just fine. There was no issues leading up to this. Any advice is appreciated thanks.
By Gary Skriba
just got a 99 Kawasaki bayou replace the coil because the spark was very weak still have the same issue before it would start after a while that it would start everyday as long as you started it every day but if you let it set you play hell starting it looking for information on what could possibly be wrong maybe the CDI box not sure any help would greatly be appreciated thank you
