Sounds like you have a good amount of oil leaking into your cylinder. Most likely worn piston/rings or valve guides/seals. Could also be a blown gasket or o-ring letting the oil that flows up to the head into the cylinder. Make sure you have not overfilled the engine oil. If the oil level is ok, then it sounds like you need to start taking the motor apart. I would strongly recommend buying a repair manual.
Too much oil would not cause the motor to knock, not enough oil would though. Any time you tear into the motor, there is a certain degree of difficulty, how hard is really a matter of how good you are at working on things.
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
